matferronato
2 years agoEarly timing analysis + Intel's IP
Hello, I updated Quartus Prime Pro to version 23.4, which gives me access to the Early Timing Analysis using RTL-on-SDC files. The majorities of my clocks are defined by the sdc files automatically...
matferronato
2 years agoHi TingJiang, thanks for the answer.
My problem happens during early timing analysis following the dni flow on quartus 23. Can you please explain your suggestion a little further?
Timing analyzer currently does not fetch the correct clocks from the ips sdc files. I cannot see the pcie clock being loaded.
