18 years agoEarly Pin Planning (without HDL)
Here's my question: When you are doing early design pin-planning (checking I/O assignments without any HDL files), how do you enter buses? For example, I have mybus[255..0] that I want to get into Quartus.
- I can use a handy text editor to directly edit the QSF, but 256 pins is a lot of times to write mybus[x] (even with cut & paste). - I can put mybus[0] into the "To" column in the assignment editor and drag the lower-right corner of the cell down 256 rows (Quartus will auto-increment), but I haven't found a nice way to add 256 empty rows into which I can drag these 256 "mybus" entries. - I can use the pin planner and create a group (Assignments -> Assignment (Time) Groups...) called mybus[255..0] and add mybus[255..0] as members of the group, but that messes up the pin planner and just shows 256 mybus lines in the "all pins" box but refusing to display a group called mybus[255..0] or assign any pins to the group. - In the pin planner, I can create a group called "foobar" and add mybus[255..0] to it. This almost works, creating 256 "mybus" entries in the "all pins" box and making them part of the "mybus" group, but it puts "mybus" as a sub-group of "foobar" in the "groups" box and won't treat "mybus" as a stand-alone group. The desired behavior is to have Quartus allow me to enter "mybus[255..0]" as a group that I can assign I/O standards to and "reserve pin" assignments and still allow me access to individual "mybus[x]" pins (for location assignments). I want to get this without having to individually create 256 entries in the pin planner or assignment editor and without me having to write HDL yet. I want to type "mybus[255..0]" somewhere in the Assignment Editor or the Pin Planner and end up with 256 lines in the QSF file that looks like: set_instance_assignment -name RESERVE_PIN "AS INPUT TRI-STATED" -to mybus[0] set_instance_assignment -name RESERVE_PIN "AS INPUT TRI-STATED" -to mybus[1] ... set_instance_assignment -name RESERVE_PIN "AS INPUT TRI-STATED" -to mybus[255] (This is what you get if you start with HDL as your design input) The best you can get in the pin planner ("mybus" as a sub-group under the "foobar" group as mentioned above) is actually not even close to that. The foobar example creates explicit assignment groups in the QSF: set_global_assignment -name ASSIGNMENT_GROUP_MEMBER mybus[255..0] -section_id foobar And although you can't create this in the pin planner, if you manually put: set_global_assignment -name ASSIGNMENT_GROUP_MEMBER mybus[255..0] -section_id mybus[255..0] in the QSF file, then the pin planner doesn't recognize this as a group to display in the "groups" box (but does prevent you from assigning any of the mybus[x] pins in the "all pins" box to any other group). Arrrrg. Are you all just writing the HDL? Or is there some magic way to do this that I'm too tired to figure out?
