15 years agoDual-Purpose Pins in Quartus 10.0
Hello there,
i have switched my project from Quartus 8.2 to Quartus 10.0 My Configuration scheme is Active Parallel. (Active Serial has the same problem). After Device configuration i want to use the configuration pins as regular IO's. My Problem: Under Quartus V10.0 i can not set the Dual-Purpose Pins to "Use as regular I/O". DCLK can only set to "Use as programming pin" Data[1]/ASDO can only set to "As input tri-stated" Data[7..2] can only set to "As input tri-stated" FLASH_nCE/nCSO can only set to "As input tri-stated" Other Active Parallel pins can only set to "As input tri-stated" Is this a Quartus 10.0 problem ?
