15 years ago --- Quote Start --- Thanks, great idea. It is a GUI issue. If i set the assignments as follow in the .qsf before i compile the design, there is no error and the fitter completes his job. set_global_assignment -name RESERVE_FLASH_NCE_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DATA0_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DATA1_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DCLK_AFTER_CONFIGURATION "USE AS REGULAR IO" --- Quote End --- I have try this mathod, but I can not access the epcs still.(I can read epsc when i use Quartus 9.0)
