Altera_ForumHonored Contributor15 years agoDual-Purpose Pins in Quartus 10.0 Hello there, i have switched my project from Quartus 8.2 to Quartus 10.0 My Configuration scheme is Active Parallel. (Active Serial has the same problem). After Device configuration i want t...Show More
Altera_ForumHonored Contributor15 years agoThanks for your help. I will wait for the first service pack.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
