15 years ago --- Quote Start --- As a temporary workaround, you can try to specify a different configuration scheme in device configuration (e.g. PS), but actually use AS. I had to use this solution in some cases with previous Quartus revisions. --- Quote End --- Thanks, i have set the configuration scheme to PS. Now i can set all pins to "Use as regular I/O". exeptionn DCLK. DCLK still can only set to "Use as programming pin". Compilation is aborded with the message: Error: Can't place multiple pins assigned to pin location Pin_K2 (IOPAD_X0_Y27_N14) Info: Pin dclk is assigned to pin location Pin_K2 (IOPAD_X0_Y27_N14) Info: Pin ~ALTERA_DCLK~ is assigned to pin location Pin_K2 (IOPAD_X0_Y27_N14) So i still can not use the EPCS Controller in my design, because i can not set all general purpose pins to "Use as Regular I/O"
