12 years ago
Dual Port RAM acces in VHDL
i read a lot of similar threads on this topic here but i could not find a solution to my (maybe suuper simple;) ) questions.
I also would like to know if this approach is a good way to implement shared memory to pass 20 .. 30 parameters .
The basic idea is to create a shared memory location for Nios to dump parameters and VHDL modules to read these parameters.
So i created a dual port RAM in Qsys, connecting to the first slave only the data master from Nios and exporting the second slave.
i connected a VHDL module to the second slave. The whole system looks like this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8978
In Qsys the dpram was instantiated with:
datawidth 32 bit,
total memory size 32768 bytes, (which results in a 13 bit wide address bus)
single clock operation.
The Address region lasts from 0x0400_0000 to 0x0400_7FFF.
I checked if i could read and write from Nios to the memory and this works fine with:
IOWR(SHARED_MEM_BASE,0,0xF);
int a = IORD(SHARED_MEM_BASE,0);
printf("%i",a);  // results in 15
For the VHDL module i thought it is sufficient to connect the address where i want to read from and read the data from this address.
But i struggle to map the addresses.
The base_address is h"4000000" for the first memory slave but how can i now access this region through the second slave?
I would need 25 bit to reach this address but Qsys only gives me 13.
I have the feeling this is a really stupid question, but right now i am really stuck.
i read the Avalon Specification but i could not find a solution there.
Thanks to all for reading!!
Cheers
Tim
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity MemoryMaster is
port (
    clk                : in    std_logic;
    reset_n            : in    std_logic;
    --av_m_chipselect  : in    std_logic;
    av_m_write     : out    std_logic;
    av_m_read    : out    std_logic;
    av_m_address     : out    std_logic_vector(12 downto 0);
    av_m_writedata   : out    std_logic_vector(31 downto 0);
    av_m_readdata    : in   std_logic_vector(31 downto 0);
    q : out std_logic
end MemoryMaster;
-- base address shared memory 0x4000 000
architecture behave of MemoryMaster is
begin
avalon_if : process (reset_n, clk)
begin
    if ( reset_n = '0' ) then
        av_m_address <= (others => '0');
        av_m_write <= '0';
        av_m_read <= '0';
        av_m_writedata <= (others => '0');
    elsif clk'event and clk ='1' then
        --av_m_address <= (others => '0');
        --av_m_address(26) <= '1';
        av_m_address <=b"0_0100_0000_0000";
        if (av_m_readdata = x"F") then
        q <= '1';
        else
        q <= '0';
        --if ( av_m_read_n = '0'  and av_m_address = b"0" ) then
            --av_m_readdata <= reg_temp;
        --elsif ( av_m_write = '0' and av_m_address = b"1" ) then
        end if;
    end if;
end process avalon_if;
end behave;
