Hi Daixiwen,
yes you were right. I had a lot of warnings for latches.
I redesigned the state machine to one porcess holding the complete structure.I also added default values before the case statement. Now i do not get the warnings anymore. However what i am still struggling with is multiple reading from different address.
When the control signal master_setup is active, the value in the address 0x10 defines with components get initialized. (state setup_eval_var).
From there multiple variables are read from fixed memory locations and assigned to output ports. ( halfbridge_freq_scale halfbridge_duty)
But here wrong values are read and i do not know why.
When i downscale the system to only one variable everything works fine. So for example reading only halfbridge_freq_scale the system works fine.
The component them self work fine. Simulation with Modelsim or running with constants shows perfect behavior.
Am i doing something wrong with the multiple address incrementation?
case state is
when idle =>
if master_setup ='1' then
state <= setup_eval_var_addr;
elsif master_run ='1' then
state <= setup_run_addr;
elsif master_wr ='1' then
state <= setup_write_addr;
else
state <= idle;
end if;
when setup_eval_var_addr =>
av_m_clken <= '1';
av_m_cs <= '1';
av_m_byteenable <= X"F";
av_m_address <= b"0_0000_0001_0000";
state <= setup_eval_var;
when setup_eval_var =>
av_m_clken <= '1';
av_m_cs <= '1';
if av_m_rddata = X"00000001" then --read halfbridge vars
state <= setup_hb_freq_addr;
elsif av_m_rddata = X"00000002" then
state <= setup_dp_t1_addr;
elsif av_m_rddata = X"00000003" then
state <= setup_npc_freq_addr; --tbd
else
state <= idle;
end if;
-- HALFBRIDGE states for reading the desired signal frequency
when setup_hb_freq_addr =>
av_m_clken <= '1';
av_m_cs <= '1';
av_m_address <= b"0_0000_0100_0000"; --64
state <= rd_hb_freq;
when rd_hb_freq =>
av_m_clken <= '1';
av_m_cs <= '1';
halfbridge_freq_scale <= av_m_rddata; --output port to halfbridge component
state <= setup_hb_duty_addr;
-- HALFBRIDGE states for reading the signal duty cycle value
when setup_hb_duty_addr =>
av_m_clken <= '1';
av_m_cs <= '1';
av_m_address <= b"0_0000_0001_1000"; --24
state <= rd_hb_duty;
when rd_hb_duty =>
av_m_clken <= '1';
av_m_cs <= '1';
halfbridge_duty <= av_m_rddata;
if master_rd ='1' then
else
state <= idle;
end if;
