DSE II doesn't work but there are no error
I am using Ubuntu22.04LTS with QuartusPrime22.1std2 Build 922 SC Lite installed. Quartus and Questa work without any major problems, but DSE II does not work.
There is no error, but the progress remains 0% and it takes time, and neither Status nor Result is displayed. I heard that this behavior can occur when the path is long, so I tried working under /home/hara/test/Quartus, but there was no change.
I tried copying the same project to Windows10, installing QuartusPrime22.1Lite on Windows10, and trying DSE II. It worked properly.
Do I need to configure something or install additional packages in Ubuntu?
I don't know what to do because there are no errors.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance for the design upgrade to 23.1 Lite?
Richard Tan
- ittou
hi,
Sorry for the late reply. I've decided to move to 23.1 Lite.
- RichardT_altera
Richard Tan
- KennyT_altera
Unfortunately, Quartus standard edition do not support Ubuntu. What it means is that the developer do not do any testing and it might prone to bug since it is not support.
You may refer to https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html
We would strongly recommend only install the Quartus on the supported version to avoid any problem in the future.
- KennyT_altera
Sorry, I mean to say that not support Ubuntu version 22 for Quartus std edition 22.1.
I attached the readme.txt for you to refer.
- ittou
Thank you for your reply.
I referred to the following PDF:
https://cdrdv2.intel.com/v1/dl/getContent/783561?fileName=rn-qts-std-dev-support-683593-783561.pdf
It states that Ubuntu22.04 is a supported OS. Can I assume that this PDF is incorrect?
So I would like to either revert to Ubuntu20 or migrate to Quartus23
(I tried Quartus23.1, but there was a problem with ALTPLL, so I reverted to Quartus22.1).
- KennyT_altera
Let me double confirm with our development team about the OS support and get back to you.
can you install Q23.1 in the ubuntu? This will help us understand if the problem still exist in there.
- KennyT_altera
After checking, this OS should be supported, we have written a KDB on this.
https://www.intel.com/content/www/us/en/support/programmable/articles/000097709.html
We will look into your issue as soon as we can.
- RichardT_altera
I understands that the DSE is not working and stuck at 0% using Quartus 22.1 Lite Edition in Ubuntu 22.04 LTS.
How about Quartus 23.1 Lite Edition? Do you have the chance to test whether the DSE works in ubuntu 22.04 using Quartus 23.1 Lite Edition?
Richard Tan
- RichardT_altera
I able to set up the Ubuntu 22.04 LTS OS and tested both 22.1.2 and 23.1 Lite Edition.
It seems that 22.1.2 Lite Edition DSE has an issue where the 0% is shown but the DSE is running behind. I can see the dse folder is created with compilation results though. The "Status" and "Result" is likely broken and can not consolidate all the compilation results.
On the other hand, I found that 23.1 Lite Edition is working fine. Could you upgrade the design to 23.1 as the DSE is working in the latest version?
This is because for Lite/Standard Edition, it will be very difficult to get resources from engineering to fix it unless there is definitely no workaround available.
Could we get back to resolve the ALTPLL problem that you mentioned previously so the design will works in 23.1?
Thank you for understanding.
p.s. It is good practice to achieve the project as backup before upgrade any design to the later version.
Richard Tan
