DSE II doesn't work but there are no error
- 2 years ago
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
I able to set up the Ubuntu 22.04 LTS OS and tested both 22.1.2 and 23.1 Lite Edition.
It seems that 22.1.2 Lite Edition DSE has an issue where the 0% is shown but the DSE is running behind. I can see the dse folder is created with compilation results though. The "Status" and "Result" is likely broken and can not consolidate all the compilation results.
On the other hand, I found that 23.1 Lite Edition is working fine. Could you upgrade the design to 23.1 as the DSE is working in the latest version?
This is because for Lite/Standard Edition, it will be very difficult to get resources from engineering to fix it unless there is definitely no workaround available.
Could we get back to resolve the ALTPLL problem that you mentioned previously so the design will works in 23.1?
Thank you for understanding.
p.s. It is good practice to achieve the project as backup before upgrade any design to the later version.
Richard Tan
