Direct operations on strings will result in synthesis errors.
Consider the following code, which fails synthesis.
module test1 (y, clk); output wire y; input wire clk; wire wire1; assign wire1 = $signed((~"")); assign y = wire1; endmodule
However, when I use a register to store the value before performing operations, it synthesizes successfully.
module test1 (y, clk); output wire y; input wire clk; wire wire1; reg str = ""; assign wire1 = $signed(~str); assign y = wire1; endmodule
- _AK6DN_
The compiler is right, you are wrong.
I'm not even sure what you expect $signed((~"")) to return as a value. It is nonsensical.
You are doing logical bitwise negation on an empty string value. What do YOU expect that to return?
reg str = ""; wire wire1 = $signed(~str);
The first line is valid as it defines a one bit register named str that gets an initial value of "" (whatever that is, probably 1'0b but that is a guess).
The second line is valid as it returns the $signed() of the bitwise complement of a one bit register.
- RichardT_altera
The "" in the failing code represents an empty string, which is not a standard numeric literal in Verilog. The bitwise NOT operator ~ applied to a non-numeric type (empty string) is not well-defined and can lead to synthesis issues.
In line:
reg str = "";
The reg type expects a single-bit value, and "" is treated as an implicit zero or 1'b0 as mentioned by @_AK6DN_
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
