12 years ago
DAC with THDB-ADA on DE2-115
Hi there,
I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working.
Here are my waveforms from ModelSim, can somebody give me some suggestion on what I did wrong?
https://www.alteraforum.com/forum/attachment.php?attachmentid=6876
fyi: I create the data output to the board from 0-16300-0... (so that it will be a triangle waveform)
I'm still doing and glad to here from you.
Thank you,
Tan
