13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
13 years agoIf your FPGA output is q[7:0], and signal before DAC is DAC_DA[13:0], try this----------
DAC_DA[13:0]={1'b0, ~q[7], q[6:0], 5'b00000} ---------------------------------------------- I contect with technical support of THDB-ADA board. They said this board does not support DC output. I think maybe that means, if you want to get a rectangle like waveform, the shape of that will degrade or change.
