13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
13 years agoThank you very much :)
I'm think I know about this daugher board really well right now :) The reason why this board doesn't receive the DC signal is that, if you have a look at the supplied schematic, there is a high pass filter (parallel RC) at every input. I calculated it to be 1.592 KHz. So, if someone would like to deal with voice frequency, they have to build a frequency amplifier interface. The reason why I didn't get this to be solven before is that I was blindly believe their schimatic, in which the output-bit enables are inputs from that daughterboard, lol. By the way, I'm using VHDL, not Verilog :D We can discuss about this board if you like :) Regards, Tan
