13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
13 years agoHi everyone:
I am trying to use the THDB Board to create a DAC. But I have a problem, I can see my square wave.I tried connecting all the jumpers in the configuration that the manual says but it doesn't work. The assignment pin I think is correct. Could you give a hit to use it?? Thank You
