Custom IP - Suspected Interface Problem
The following attached files describe a binary-to-hex display code custom IP peripheral for Nios II. The top-level file was selected as the bin_hex_interface file. I included the .tcl (as a .txt as the file upload system wouldn't support it), .v, and .c main files. To test, I simply used the hello_world_small sample from Eclipse and then wrote code that passes a value to that custom IP and reads it back. So, for example, passing a value of 0 into it would return 0x40 as this is the value needed to write 0 into the hex displays. Unfortunately, though, this is all I can return back, no matter what value I try to write to it. I don't know if there is something wrong with my interface, the basic module hardware logic should in theory be fine (I tested it by itself but that doesn't mean I didn't mess up somewhere and my tests didn't catch it), or the macro I'm using, but something somewhere isn't working right. Please let me know what I'm doing wrong. Thanks in advance!
I apologize. I misread the documentation. Needed BOTH Verilog files to make it work. I fixed it. It's missing the byte-addressing for the architecture.
- wwanalim_intel
Contributor
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
- sstrell
When you say "this is all I can return back", are you saying that 0 is the only value that works (or works correctly)? Or are you saying that no matter what value you put in, you always get 0x40 out?
- wwanalim_intel
Contributor
I'm currently reviewing the attached design. Kindly grant me a bit more time to thoroughly examine it.
- wwanalim_intel
Contributor
Where do you get the custom IP design?
- wwanalim_intel
Contributor
Do you have any updates to share?
I would need your response to have a better understanding about the issue.
- wwanalim_intel
Contributor
- road_runner
