road_runner
2 years agoCustom IP - Suspected Interface Problem
Hello, The following attached files describe a binary-to-hex display code custom IP peripheral for Nios II. The top-level file was selected as the bin_hex_interface file. I included the .tcl (as a ...
- 2 years ago
I apologize. I misread the documentation. Needed BOTH Verilog files to make it work. I fixed it. It's missing the byte-addressing for the architecture.
sstrell
2 years agoWhen you say "this is all I can return back", are you saying that 0 is the only value that works (or works correctly)? Or are you saying that no matter what value you put in, you always get 0x40 out?
