dicas3d's avatar
dicas3d
3 years ago
Crosspoint/crossbar switch ip
What's the easiest way to build a crosspoint switch on Arduino Mkr Vidor 4000 FPGA chip?
There's an IP Core?
Is to build it to 96 inputs and 96 outputs, audio applications with high performance with 0 latency and the highest possible audio resolution.
    • dicas3d's avatar
      dicas3d
      The link you provided is a project to add audio support incompatible with newer versions of Quartus. To do a better understanding of what I want.
      I will use an external DSP chip, external ADC/ADC a external TDM to usb codec. The FPGA will act as crosspoint/crossbar switch between them . And decomultiplex/multiplex TDM streams to the chip.
  • Hi,
    Good day to you.
    Apologies but we don't have an IP that supports your requirement at the moment, at least not that I know of.
