dicas3d
3 years agoCrosspoint/crossbar switch ip
What's the easiest way to build a crosspoint switch on Arduino Mkr Vidor 4000 FPGA chip? There's an IP Core? Is to build it to 96 inputs and 96 outputs, audio applications with high performance with...
paveetirrasrie_Altera
3 years agoHi,
Unfortunately we don't have any IP that support your requirement for now. You may visit Arduino Website to check the design availability that matches your protocol. Anyways, I have attached a RocketBoard link where I think it maybe useful for you.
https://www.rocketboards.org/foswiki/Projects/AudioSupportWithXillinuxForCycloneVSoC
Pavee
dicas3d
3 years agoThe link you provided is a project to add audio support incompatible with newer versions of Quartus. To do a better understanding of what I want.
I will use an external DSP chip, external ADC/ADC a external TDM to usb codec. The FPGA will act as crosspoint/crossbar switch between them . And decomultiplex/multiplex TDM streams to the chip.
