15 years ago
Creating Flip-flop by using logic gates
I am a student who new to VHDL and currently doing VHDL assignment. In this assignment, students are required to create the D, JK flip-flop.
I need help to solve my error for my code as shown as below:
library ieee;
use ieee.std_logic_1164.all;
entity Dflip_flop is
port
D :in std_logic;
clk :in std_logic;
Q :out std_logic;
Qbar :out std_logic
end Dflip_flop;
architecture hc of Dflip_flop is
signal W1 : std_logic;
signal W2 : std_logic;
signal W3 : std_logic;
signal W4 : std_logic;
signal W5 : std_logic;
begin
Q <= W4;
Qbar <= W5;
W1 <= not D;
W2 <= D nand clk;
W3 <= clk nand W1;
W4 <= W2 nand W5;
W5 <= W3 nand W4;
process(clk)
begin
if rising_edge(clk)then
Q <= D;
end if;
end process
end hc;
Error (10500): VHDL syntax error at Dflip_flop.vhd(41) near text "end"; expecting ";", or an identifier ("end" is a reserved keyword)
Can anyone point out what is the syntax error here??
Thanks and appreciated for the helps.
    Besides that, i also faced a prob when designing the JK flip-flop.
    In this assignment, students are required to simulate the result in the functional and timing mode..
    By using the code as shown as below:
    library ieee;
    library work;
    entity JKflip_flop is
    port
    J :in std_logic;
    K :in std_logic;
    clk :in std_logic;
    Q :out std_logic;
    Qbar :out std_logic
    end JKflip_flop;
    architecture hc of JKflip_flop is
    signal W6 : std_logic;
    begin
    Q <= W3;
    Qbar <= W4;
    W1 <= not (J and clk and W4);
    W2 <= not (K and clk and W3);
    W3 <= W1 nand W4;
    W4 <= W2 nand W3;
    end hc;
    It can only simulate only in the timing mode and it show nothing in the functional mode. I cant find a reason y this will happened??
    Anyone knows y tis happened?? Did it need any settings in quartus to make so that it can simulate in the functional mode???
    Thank you.
    --- Quote Start ---
    --- Quote End ---
    first of all, you need a semicolon on the end of the "end process" line.
    Second of all, you'll have problems with this, as Q has multiple drivers. Q is driven from the process, and from W3. Are you sure you want the process there?
    For the second question, what are you similating with? have you written a testbench?
    Hi Tricky,
    For the 1st question, I will faced the Q is multiple drivers problem if i process there.. Actually i just wan to add on 1 statement in my coding which is " if rising_edge(clk) then
    Q <= D" I just have a try to have a process statement in my coding and i don't know where should i put the process statement. Any suggestion??
    For the 2nd question, testbench are not written. I just go the simulator settings to set the simulation mode to "functional" and start the vector waveform simulation.
    --- Quote Start ---
    --- Quote End ---
    Keep the process - get rid of the logic version (or have a separate output for it). You description of a D-type with a process is correct.
    --- Quote Start ---
    --- Quote End ---
    What simulator are you using?
    There was a similar thread few days ago under the same topic "creating flipflops by using logic gates".
    I will point out that your design defeats the purpose because you are not creating D flop from logic but you are inferring it at:
    Q <= D;
    thus you might not impress your professor...
