15 years agoBesides that, i also faced a prob when designing the JK flip-flop.
In this assignment, students are required to simulate the result in the functional and timing mode.. By using the code as shown as below: ------------- library ieee; use ieee.std_logic_1164.all; library work; entity JKflip_flop is port ( J :in std_logic; K :in std_logic; clk :in std_logic; Q :out std_logic; Qbar :out std_logic ); end JKflip_flop; architecture hc of JKflip_flop is signal W1 : std_logic; signal W2 : std_logic; signal W3 : std_logic; signal W4 : std_logic; signal W5 : std_logic; signal W6 : std_logic; begin Q <= W3; Qbar <= W4; W1 <= not (J and clk and W4); W2 <= not (K and clk and W3); W3 <= W1 nand W4; W4 <= W2 nand W3; end hc; ---------------- It can only simulate only in the timing mode and it show nothing in the functional mode. I cant find a reason y this will happened?? Anyone knows y tis happened?? Did it need any settings in quartus to make so that it can simulate in the functional mode??? Thank you.
