15 years ago --- Quote Start --- Error (10500): VHDL syntax error at Dflip_flop.vhd(41) near text "end"; expecting ";", or an identifier ("end" is a reserved keyword) Can anyone point out what is the syntax error here?? Thanks and appreciated for the helps. --- Quote End --- first of all, you need a semicolon on the end of the "end process" line. Second of all, you'll have problems with this, as Q has multiple drivers. Q is driven from the process, and from W3. Are you sure you want the process there? For the second question, what are you similating with? have you written a testbench?
