dsun01
Contributor
4 years agocouldn't run EDA simulation library compiler
Dear Support,
I am learning how to use Quartus Pro, under tools-> launch simulation library compiler, I filled the executable location correctly. I confirmed that the vsim is there. but the tools keep asking me to "specify the simulation tools executable location. this really confuse me.
please give instruction/hint how to set up the location correctly. the Quartus is 21.3.
the Questa is 2021.04.
thank you
David Sun
the problem is the IP variation is not using the original IP name. just recompile the original IP with simulation enabled. will solve the problem.
David
