dsun01
Contributor
4 years agocouldn't run EDA simulation library compiler
Dear Support,
I am learning how to use Quartus Pro, under tools-> launch simulation library compiler, I filled the executable location correctly. I confirmed that the vsim is there. but the tools...
- 4 years ago
the problem is the IP variation is not using the original IP name. just recompile the original IP with simulation enabled. will solve the problem.
David
SyafieqS
4 years agoSince the issue had been solved, I close pending it.
