dsun01
Contributor
4 years agocouldn't run EDA simulation library compiler
Dear Support,
I am learning how to use Quartus Pro, under tools-> launch simulation library compiler, I filled the executable location correctly. I confirmed that the vsim is there. but the tools...
- 4 years ago
the problem is the IP variation is not using the original IP name. just recompile the original IP with simulation enabled. will solve the problem.
David
Eifel
4 years agoHello!
I have the same problem. Sorry for such a question What's the IP variation? How can I recompile it? I think my simple project doesn't use any IP cores if that's the problem.
