12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- @kaz I don't see anything stupid in the simulation. No idea why I am getting this delay now. --- Quote End --- I take it that there is no such delay in simulation but in hardware. Did you see sum building up soon and avg taking values. In that case revise your design and use signaltap. Check your clocking scheme. Your adc samples should be sampled into filter at 19.5KHz. since your clock is 312KHz I therefore assume your done = '1' is enabling clock at 19.5KHz.
