12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago@kaz
If I dont put '0', I get the following error. Should I reduce subtractor bits? Error (10344): VHDL expression error at adc_cntrl.vhd(160): expression has 12 elements, but must have 13 elements. Can you tell me how can I use one computation section for both switching between them at input to delay section? Can you modify my code? Many Thanks
