11 years agoConfiguring Transceiver Pins for Cyclone V GX: 1.5V PCML
Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following:
Transmitter Input differential impedance 100-ohms Single ended data input swing min(90mV) max(350mV) Receiver Single ended data output swing min(275mV) max(425mV) I intend to use the Altera Transceiver PHY IP core to interface with the fiber-optic transceiver. I have been looking over the Cyclone V Datasheet and I believe that should configure the tx/rx differential pins to 1.5V PCML. Also, on page 22 table 21 it lists the TX Vod settings. I believe that I should choose Vod setting 16 which is Vod value 320mV, is that correct? Using Table 20 I get the following: Transceiver (AC Coupled) Vod (max) = 1200mV Vod (typ) = -- Vod (min) = -- Vocm = 0.65V Receiver (AC Coupled) Vid (max) = 1600mV Vid (typ) = ---- Vid (min) = -- Vicm = 0.8V I am have not used the Altera transceivers before so what I have described so far does anyone see any red flags? The fiber-optic transceiver has integrated capacitors so I'm thinking of simply connecting the fpga right up to the transceiver tx/rx pins. If anyone has experience with this please share any comments you may have. thanks, joe7 Replies
You had solved?
--- Quote Start --- Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential impedance 100-ohms Single ended data input swing min(90mV) max(350mV) Receiver Single ended data output swing min(275mV) max(425mV) I intend to use the Altera Transceiver PHY IP core to interface with the fiber-optic transceiver. I have been looking over the Cyclone V Datasheet and I believe that should configure the tx/rx differential pins to 1.5V PCML. Also, on page 22 table 21 it lists the TX Vod settings. I believe that I should choose Vod setting 16 which is Vod value 320mV, is that correct? Using Table 20 I get the following: Transceiver (AC Coupled) Vod (max) = 1200mV Vod (typ) = -- Vod (min) = -- Vocm = 0.65V Receiver (AC Coupled) Vid (max) = 1600mV Vid (typ) = ---- Vid (min) = -- Vicm = 0.8V I am have not used the Altera transceivers before so what I have described so far does anyone see any red flags? The fiber-optic transceiver has integrated capacitors so I'm thinking of simply connecting the fpga right up to the transceiver tx/rx pins. If anyone has experience with this please share any comments you may have. thanks, joe --- Quote End --- - Altera_Forum
Thieulam,
Hello, that was a long time ago and I never received any help from the Forum or Altera. At that time my co-worker saw no red flags. That board has not been built yet and I've had to change to a larger Cyclone. I will be revisiting this again to make sure things are correct. I will let you know how things turn out. Joe - Altera_Forum
thank you Joe.
I have the same problem with cycloneVgx starter kit (terasic). I would like to use an SFP module with CML ac coupled interface. But I do not understand if the standards 1.5V PCML is compatible .. --- Quote Start --- Thieulam, Hello, that was a long time ago and I never received any help from the Forum or Altera. At that time my co-worker saw no red flags. That board has not been built yet and I've had to change to a larger Cyclone. I will be revisiting this again to make sure things are correct. I will let you know how things turn out. Joe --- Quote End --- - Altera_Forum
Hello, it is my understanding that they are compatible. I did have some questions so I referred to Cyclone V Device Datasheet pages 16-18 regarding 1.5V PCML. Here is what I have found.
Transceiver (AC Coupled)Vod (max) = 1200mVVod (typ) = 660mV (my co-worker found this somewhere) Vod (min) = 120mV (my co-worker found this somewhere) Vocm = 0.65VReceiver (AC Coupled) Vid (max) = 1600mVVid (typ) = 200mV(my co-worker found this somewhere) Vid (min) = 700mV(my co-worker found this somewhere) Vicm = 0.8V I also contacted the vendor of the SFP which was very helpful. You might consider contacting a Field Applications Engineer from Altera, must open a Service Ticket with Altera, ask you questions and also ask contact an FAE. I think you will be okay. - Altera_Forum
Thank you.
I open a ticket with altera. Regards, Luca --- Quote Start --- Hello, it is my understanding that they are compatible. I did have some questions so I referred to Cyclone V Device Datasheet pages 16-18 regarding 1.5V PCML. Here is what I have found. Transceiver (AC Coupled)Vod (max) = 1200mVVod (typ) = 660mV (my co-worker found this somewhere) Vod (min) = 120mV (my co-worker found this somewhere) Vocm = 0.65VReceiver (AC Coupled) Vid (max) = 1600mVVid (typ) = 200mV(my co-worker found this somewhere) Vid (min) = 700mV(my co-worker found this somewhere) Vicm = 0.8V I also contacted the vendor of the SFP which was very helpful. You might consider contacting a Field Applications Engineer from Altera, must open a Service Ticket with Altera, ask you questions and also ask contact an FAE. I think you will be okay. --- Quote End --- - Altera_Forum
--- Quote Start --- Thank you. I open a ticket with altera. Regards, Luca --- Quote End --- Hello, I have the same doubt. Instead of launching another request to Altera, would you be able to share with us the answer Altera gives you? Thank you. Best regards, Carlos - Altera_Forum
The answer of altera:
The PCML is compatible with any CML sfp ac coupled. --- Quote Start --- Hello, I have the same doubt. Instead of launching another request to Altera, would you be able to share with us the answer Altera gives you? Thank you. Best regards, Carlos --- Quote End ---
