11 years agoConfiguring Transceiver Pins for Cyclone V GX: 1.5V PCML
Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential imp...
10 years agoThe answer of altera:
The PCML is compatible with any CML sfp ac coupled. --- Quote Start --- Hello, I have the same doubt. Instead of launching another request to Altera, would you be able to share with us the answer Altera gives you? Thank you. Best regards, Carlos --- Quote End ---
