11 years agoConfiguring Transceiver Pins for Cyclone V GX: 1.5V PCML
Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential imp...
10 years agoHello, it is my understanding that they are compatible. I did have some questions so I referred to Cyclone V Device Datasheet pages 16-18 regarding 1.5V PCML. Here is what I have found.
Transceiver (AC Coupled)Vod (max) = 1200mVVod (typ) = 660mV (my co-worker found this somewhere) Vod (min) = 120mV (my co-worker found this somewhere) Vocm = 0.65VReceiver (AC Coupled) Vid (max) = 1600mVVid (typ) = 200mV(my co-worker found this somewhere) Vid (min) = 700mV(my co-worker found this somewhere) Vicm = 0.8V I also contacted the vendor of the SFP which was very helpful. You might consider contacting a Field Applications Engineer from Altera, must open a Service Ticket with Altera, ask you questions and also ask contact an FAE. I think you will be okay.
