11 years agoConfiguring Transceiver Pins for Cyclone V GX: 1.5V PCML
Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential imp...
10 years agothank you Joe.
I have the same problem with cycloneVgx starter kit (terasic). I would like to use an SFP module with CML ac coupled interface. But I do not understand if the standards 1.5V PCML is compatible .. --- Quote Start --- Thieulam, Hello, that was a long time ago and I never received any help from the Forum or Altera. At that time my co-worker saw no red flags. That board has not been built yet and I've had to change to a larger Cyclone. I will be revisiting this again to make sure things are correct. I will let you know how things turn out. Joe --- Quote End ---
