11 years agoConfiguring Transceiver Pins for Cyclone V GX: 1.5V PCML
Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential imp...
10 years agoYou had solved?
--- Quote Start --- Hello, I am using the Cyclone V GX to interface with a Fiber-optic transceiver that is CML. The datasheet for the Fiber-optic transceiver has the following: Transmitter Input differential impedance 100-ohms Single ended data input swing min(90mV) max(350mV) Receiver Single ended data output swing min(275mV) max(425mV) I intend to use the Altera Transceiver PHY IP core to interface with the fiber-optic transceiver. I have been looking over the Cyclone V Datasheet and I believe that should configure the tx/rx differential pins to 1.5V PCML. Also, on page 22 table 21 it lists the TX Vod settings. I believe that I should choose Vod setting 16 which is Vod value 320mV, is that correct? Using Table 20 I get the following: Transceiver (AC Coupled) Vod (max) = 1200mV Vod (typ) = -- Vod (min) = -- Vocm = 0.65V Receiver (AC Coupled) Vid (max) = 1600mV Vid (typ) = ---- Vid (min) = -- Vicm = 0.8V I am have not used the Altera transceivers before so what I have described so far does anyone see any red flags? The fiber-optic transceiver has integrated capacitors so I'm thinking of simply connecting the fpga right up to the transceiver tx/rx pins. If anyone has experience with this please share any comments you may have. thanks, joe --- Quote End ---
