16 years ago
Compilation time for Quartus II 9.0
I have recently upgraded Quartus II from 7.3 SP2 to 8.1 and am very happy with the compilation speed (about 25% faster in my case). But does anyone know how much faster the 9.0 is comparing to 8.1? Any reason not to upgrade to 9.0 at this point?
Thanks in advance.
Hua
    I guess I'm talking a bit weird again... sorry ;)
    I have a negative total hold slack for two out of ten seeds. So I'm rather trying to get zero instead of something negative, not optimising positive values.
    I'm not trying to push the hold time slack to zero from any direction (guess that is what you question was). I'm just trying to "fix" (optimise is too positive here) a very bad timing.
    If you have a gated clock, and therefore have clock skew so the latching clock is longer than the launching clock, you end up having to add delays to meet hold timing. So even though the requirement is 0ns, in essence it still has to add delay to meet timing. Naturally anything that can be done in the code to fix this would be good. (Like moving the gating signals from logic to drive the enable of the altclkctrl block...)
    How long is the route time compared to placemen? Most designs it's much less, say 5%, but your design may be skewed. Also curious what the average and peak routing utilization is? (in .fit.rpt). And do you have Optimize Fast Corner checked?
    (I think you're aware of all this, just double-checking...)
    Yes, we definitely need a lot of delay introduced. I haven't tried to run without optimize hold timings for some time, but I guess I would end up somewhere in the micro-seconds range TNS.
    I can't currently do much against that, as the ASIC design is quite frozen atm. The only thing I'm not sure is if I could push the clock gating conversion for a better result with other timing constraints and a smart clock gating cell replacement. It doesn't convert anything right now.
    Concerning elapsed times:
    Info: Fitter placement operations ending: elapsed time is 00:21:32
    Info: Fitter routing operations ending: elapsed time is 02:06:53
    So I'm on the far other end then, I need 600% for the routing :-/
    Concerning utilisation:
    Info: Average interconnect usage is 15% of the available device resources
    Info: Peak interconnect usage is 55% of the available device resources
    But I have seen much higher values here, this one is for a quite nice fit. Logic utilization is 33%.
    I have the optimize fast corner timing checked for 8.1. But I recently uncecked the optimize multi corner timing in 9.0, hoping to reduce the compile time somewhat.
    Yowsers. At the end of the day, I think it is what it is. Routing is probably the biggest use of silicon in an FPGA, so they're really not designed to have lots of extra resources to fix hold violations. You may try to manually add delay to your clock trees and see if theres any way to balance them. (I don't know how many clocks you have, if they're on globals, etc.) One other thing of note is that in Q9.0 they added an "Estimated Delay Added for Hold" table, or something like that. You're already aware of why it's being added, but might be a good chart to gauge what the router is doing.
    Getting quite off-topic here...
    I've been messing around with different kinds of location assignments, trying to release the fitter, but somehow it was always worse (what a wonder...). There is always a point where the skew ends up in a loop.
    We have some 20 clocks here, thereof about 5 asynchronous. The good part of the dividers are ripple counters (I hope there is no student or professor reading that now...). So somehow, I'm not really surprised by the bad result ;)
    The only disappointing thing is the clock gating conversion introduced in Q8.1. From a colleague I know that Synplify managed to convert the tree.
    Anyway, we are probably starting a new version this summer, so I'll try to fix this mess somewhat. They were running into problems on the ASIC as well, just much less.
    So back to the topic: This will also reduce the compilation time heavily I guess.
