Compilation differences between Quartus Prime and Design Space Explorer
- 3 years ago
The margin is a couple hundred pico-seconds. If you can't align them, what is the point of using Design Space Explorer? It becomes a difficult tool to use.
However, I solved my own problem: I was able to align the two. The number of processors specified has to be the same in both environments for the results to be the same. Once those were changed to be the same, Design Space Explorer produced the same compilation results as Quartus.
