CFM0 Overlaps with Configuration Data (Error 20646 Quartus Prime)
- 1 year ago
obviously, userdata start addresses of 0x41000 and 0x83000 are not suitable for 10m25 flash layout. If you want to keep the distance from CFM1 and CFM0 end address (-0x9000) , they should be changed to 0x5b000 and 0xb7000.
P.S.: I don't work with NIOS II and am not aware of the relation between start adresses and vectors shown in post #1 for 10m16. But basically everything should be relocated according to increased CFM1 and CFM0 flash size.
RegardsFrank
I was comparing CFM1 and CFM0 area of both devices.
CFM1 (usually application image) memory range 0x08000 - 0x49fff on 10M16 and 0x08000 - 0x63fff on 10M25
CFM0 (usually factor image) memory range 0x4a000 - 0x8bfff on 10M16 and 0x64000 - 0xbffff on 10M25
User data is placed in upper free space of each block.
