ashbinbabu
1 year agoCFM0 Overlaps with Configuration Data (Error 20646 Quartus Prime)
Hi, We are using 10M25 for the design of our PFR enabled FPGA code for a server motherboard. Here we have partitioned CFM0 for recovery image and CFM1 for the active image. We had a reference design...
- 1 year ago
obviously, userdata start addresses of 0x41000 and 0x83000 are not suitable for 10m25 flash layout. If you want to keep the distance from CFM1 and CFM0 end address (-0x9000) , they should be changed to 0x5b000 and 0xb7000.
P.S.: I don't work with NIOS II and am not aware of the relation between start adresses and vectors shown in post #1 for 10m16. But basically everything should be relocated according to increased CFM1 and CFM0 flash size.
RegardsFrank
ashbinbabu
1 year agoHi Frank,
Can you show an example on how you calculate these new recommended offsets?
Ashbin
