16 years ago
Can't resolve multiple constant drivers?
Hi, ive been trying to compile the code below in quartus II v9.0 and i get the following error message Error (10028): Can't resolve multiple constant drivers for net "LSD_SEG[0]" at KEYBOARD.VHD(385)
ive tried to solve this since friday, now im out of options. the problem here is, i assign values to MSD_SEG & LSD_SEG from 3 different processes and quartus doesnt like that. i tried combining processes but only the push buttons (PB1 and PB2) are working and the keyboard isnt. The code compiles fine in Maxplus II but the thing is, Maxplus II doesnt support EP2C20F484CN FPGA (Cyclone II development board DE1). pls help
    No Problem. with VHDL you can write whatever VHDL you want and have it simulate fine, but if it isnt written with recommended coding styles you cant guarantee that the synthesised firmware will work.
    Did you set any timing requirements when you say it doesnt throw any warnings?
    For all VHDL you are going to synthesize, the recommended style for a clock process (to generate registers) is this:
    reg_proc : process(clk, reset)
    begin
      if reset = '1' then
        --asynchronous reset
      elsif rising_edge(clk) then
        --registered statements go here
        if enable = '1' then
          --register with enable statements go here
        end if;
      end if;
    end process;
    Using wait statements in process is allowed, but not a common form. It can be safer to use the rising_edge(clk) method above, because more people will have seen it and I know all synthesisors will work with it. Use wait statements to your hearts content in testbenches (where they can be very useful for creating bus functional models).
    As you are new to VHDL, can I also recommend you stop using std_logic_arith and std_logic_signed/unsigned now. They are non-standard packages. They have become a bit of a defacto standard. The real IEEE standard is numeric_std, which I recommend using over the other 2 packages. it allows you to do signed and unsigned arithmatic in the same file (the other method does not) and with proper typing and much better named functions it makes more sense. It is also compatible with the new standardised fixed point libraries for doing really easy fixed point maths.
    Another thing to remember is that internal ports on entites (ie. ones that dont connect to pins) can be any type you want - so use integers/boolean/enummerated types to make your code much more readable.
    Any other questions, please ask away.
    --- Quote Start ---
    begin
      if reset = '1' then
        end if;
      end if;
    end process;
    --- Quote End ---
    Ohk Tricky thanx. i get the timing warnings but they dont matter for now because ive tested both keyboard process and push button processes independently and they work fine. the problem is to get them to work together. can you please help me with that? look at the code and try to see what can be done to resolve the issue. pls try to compile it, ull see what im talking about.
    Dante
