12 years ago
Cannot create an Internal Memory Initialization (.hex) File
I'm a beginner in Nios II software development.
I used the Quartus 13.0, the Qsys and the Nios II EDS for Eclipse to create the count_binary example for the CycloneIII_3c25 Starter Kit.
Everything is OK if "Run As -> Nios II Hardware" is used.
But I cannot create an Internal Boot Memory Initialization (.hex) File.
I follow the steps to create memory initialization files in the Nios II Software Developer's Handbook.
1. Right-click the application project.
2. Point to Make targets and click Build to open the Make Targets dialog box.
3. Select mem_init_generate.
4. Click Build.
5. Add the .qip (meminit.qip) file to the Quartus II project.
But I cannot find the .hex files
6. Recompile the Quartus II project.
After it I see the warning "Can't find design file <Project name>_mem.hex"
There is another way to create memory initialization file - to use the mem_init.mk
But how one can include this file in the application makefile and how a target can be set properly is unknown.
Any idea?
tduty
