12 years agoIn some driver implementations, the JTAG UART driver hangs the CPU if the nios console isn't connected. This could be what happened here? Do you have any command in your application that writes something to the console? In that case try to switch a LED before any console print, and check if you get at least a change on the LEDs before the CPU hangs.
