12 years agoHello, benc!
I've done you advised but nothing changed. To be able to save the .hex file after it's opened and the word size is changed to 32 I was to change a symbol in the file and then to restore it. Without it I could not save (unchanged) file. By the way I noticed the meminit.qip file contains the only string, i.e. set_global_assignment -name SEARCH_PATH $::quartus(qip_path) Is it enough for Quartus compiler to find the necessary .hex file? Regards, tduty
