AndreVR
1 year agoCannot configure MAX 10 Eval with .sof
My program compiles without error. I cannot load the .sof or .pof file When I open the programmer the FPGA is visible in the window and the .sof file is loaded. When I hit Start the Progess window s...
AndreVR
1 year agoThank you for your reply.
Yes, the PcbTest program is closed. In the meantime, I managed to program the .sof file successfully. However, I’m unsure about the correct setup for the JTAG chain in the programmer window. The only way I can get a successful programming status is if I have two “..484C6GES” devices visible and select the left device. I’ve created a simple program to toggle the user LED D15 (I also tried the other LEDs), but there’s no activity on the LEDs, indicating the program may not be running. Could you please help?
BXia
1 year agoYou'd better provide screenshot for the Programmer tool window, normally there should be only one device after doing autodetect.
And you need to check if led pin is assigned correctly.
