In the Assignment Editor, select "Parameters" near the bottom of the "Category" list. I think this will override parameters explicitly set in the RTL, but I don't remember for sure.
Here's by far the most common usage of it, which is used when a piece of IP targets a specific RAM type and the end user wants to force it to a different type:
http://www.altera.com/support/kdb/solutions/rd02172004_713.html?gsa_pos=6&wt.oss_r=1&wt.oss=m4k%20m-ram - Altera_Forum
Hi Brad and Rysc,
I appreciate your answer. It looks work well. Regards - Altera_Forum
Digging an old one up here.
Does anybody now how this translates to assignments in the qsf? I'm trying to change the value of a top level block VHDL generic in different build revisions. Thanks. - Altera_Forum
i've used VHDL packages for that (you could call in different packages with the .qsf or other build script)
however, here's the parameter in the .qsf: set_parameter -name my_param my_value - Altera_Forum
Yes changing a package in the qsf would be an option but we potentially have many variations (based on the generic) of the same build and hence many qsfs. So what we are going to do is set up the project with a bash script that changes the single paramater setting in some tcl accordingly, and then runs the tcl to set up the project.
I've got a top level called "fred_top" with a generic called "width" which by default is 8. What I try and do is change that value by setting the following in the qsf but unfortunaletly it doesn't seem to work.
Any ideas appreciated.set_parameter -name width 16 -to fred_top - Altera_Forum
i will see if i can test the Quartus parameters instead of VHDL packages
if you're really stuck you could make the bash script generate the VHDL package on the fly based on the parametrization (same .vhd name so no changes to .qsf) - Altera_Forum
Pancake,
This is some code I knocked up to test it...
If you manually change the frog generic from 1 to 2 it changes which mx_comp is generated in Quartus, as you would expect. Nw to do this is the qsf I used...library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fred is generic ( frog : integer := 1 ); port ( in1 : in std_ulogic_vector (3 downto 0); in2 : in std_ulogic_vector (3 downto 0); sel : in std_ulogic_vector (3 downto 0); out1 : out std_ulogic_vector (3 downto 0)); end fred; architecture RTL of fred is -- component mx_comp_1 port( in1 : in std_ulogic; in2 : in std_ulogic; sel : in std_ulogic; out1 : out std_ulogic); end component; -- component mx_comp_2 port( in1 : in std_ulogic; in2 : in std_ulogic; sel : in std_ulogic; out1 : out std_ulogic); end component; begin GEN: for n in 3 downto 0 generate COND1 : if (frog = 1) generate mx1g : mx_comp_1 port map ( in1 => in1(n), in2 => in2(n), sel => sel(n), out1 => out1(n) ); end generate; COND2 : if (frog = 2) generate mx2g : mx_comp_2 port map ( in1 => in1(n), in2 => in2(n), sel => sel(n), out1 => out1(n) ); end generate; end generate; end RTL;
In this case fred is the top level. It did not work. Now either I'm doing something wrong or it's simply not working. Thanks for your effort on this.set_parameter -name frog 2 -to fred - Altera_Forum
It work's exactly as suggested above:
--- Quote Start --- set_parameter -name my_param my_value --- Quote End --- Please consider, that in VHDL parameters can be only set for the top entity, not down the hierarchies. Thus the set_parameter tcl command doesn't need/understand an entity name here. - Altera_Forum
FvM brilliant, thanks.
It seems all I had to do is drop the -to option. Just using this works...
Thanks.set_parameter -name frog 2
