Altera_ForumHonored Contributor17 years agoCan parameter or generic be set from Quartus II? Hi, Is there any way to set values to parameter or generic in Verilog/VHDL RTL code with the Quartus II? I want to change the parameters inside megacore without modifting RTL code. ThanksShow More
Altera_ForumHonored Contributor17 years agoHi Brad and Rysc, I appreciate your answer. It looks work well. Regards
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
