can not install eclipse(v19.3) with ubuntu18.04
hello, i install eclipse with ubuntu 18.04, when i use eclipse,i got this error message "
root@smart-HP:~/intelFPGA_pro/19.3/nios2eds/bin# ./eclipse-nios2
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
free(): invalid pointer
" and i can not use eclipse;what can i do next ?
- MEIYAN_L_Intel
From the message show you are installing the later version of JDK v8.0, but the version needed for eclipse is JDK v7.0.
Upon checking , there is a customer who face the same problem with you.
Could you try to set the environment variable as link below:
https://wiki.archlinux.org/index.php/Eclipse#Disable_GTK_3
If the problem still persist, please tell me as well.
- LZhi01
hello, thank you email,i change the .ini file as below but,when i click OK button,the eclipse is disappered. i still can not use sbt.
- MEIYAN_L_Intel
I am not able to look into the .ini file, could you try to upload the .ini file?
- MEIYAN_L_Intel
I had reported this issue to developer. I will reply here once I receive the information from the developer.
- MEIYAN_L_Intel
Sorry for late reply.
You might need to try to set environment variable by prepending "SWT_GTK3=0" before starting eclipse.
For your information, Ubuntu is not officaially supported for the Nios II EDS.
