LZhi01
6 years agocan not install eclipse(v19.3) with ubuntu18.04
hello, i install eclipse with ubuntu 18.04, when i use eclipse,i got this error message " root@smart-HP:~/intelFPGA_pro/19.3/nios2eds/bin# ./eclipse-nios2 OpenJDK 64-Bit Server VM warning: ignorin...
MEIYAN_L_Intel
6 years agoHi,
From the message show you are installing the later version of JDK v8.0, but the version needed for eclipse is JDK v7.0.
Upon checking , there is a customer who face the same problem with you.
Could you try to set the environment variable as link below:
https://wiki.archlinux.org/index.php/Eclipse#Disable_GTK_3
If the problem still persist, please tell me as well.
- LZhi016 years ago
hello, thank you email,i change the .ini file as below but,when i click OK button,the eclipse is disappered. i still can not use sbt.
