18 years agoBig Problems with bidir Pin :-)
I have a problem with the bidir pins in Quartus II. I made a simple project to demonstrate this. http://rapidshare.com/files/32982986/iobuff_test.zip.html (http://rapidshare.com/files/32982986/iobuff_test.zip.html) If oe=1, the value on "in" (which is alleways '1') should be going to "io". In the simulation you see, that the simulator generates a new variable called "io~result". This variable has the right value, which the bidirectinal pin also should have. But the bidir pin "io" allways stay "undefined". Why??? I searched for other examples with this pin but I can't find them. Is there no way to work with I/Os? It would be gratefull if someone has s solution, or better an example to handle bidirectinal pins. Regards, Chrisitan
