11 years ago
Best approach for creating clock sources please?
Hello again and more inane questions from yours truly!
I have a design which relies on many different clock sources: A lot of inter-dependent timing going on.
What therefore is the best (or 'proper') approach to creating many different clocking sources (from the same basic clock source input of course).
I know it is not 'good practice' to gate clocks to create another clock which is then used to clock say a latch or a register etc.
So, what is considered a good / acceptable clock source? The output of a state machine perhaps? The output of a counter?
Any guidelines / comments / suggestions much appreciated!
I include below VHDL of something I have written that creates an 8MHz clock from my 24MHz source:
  proc_8MHz : PROCESS (nPowerSettleDelay, M24MHz)
  BEGIN
    IF nPowerSettleDelay='0' THEN
      uM8MHz     <= '1';
      u_nM8MHz   <= '0';
      Next_State <= State_1;
    ELSIF RISING_EDGE(M24MHz) THEN
      CASE Next_State IS
        WHEN State_1 =>
          Next_State <= State_2;
          uM8MHz   <= '1';          --  1
          u_nM8MHz <= '0';          --  0
        WHEN State_2 =>
          Next_State <= State_3;
          uM8MHz   <= '0';          --  0
          u_nM8MHz <= '1';          --  1
        WHEN State_3 =>
          uM8MHz   <= '0';          --  0
      END CASE;
    END IF;
  END PROCESS proc_8MHz;
Is it 'safe' then to use either the uM8MHz or the nM8MHz signal as clock sources?
Cheers again all,
Andy
    The clock source is constant and a 'true' clock.
    I think maybe I am implementing the enable signal incorrectly....
      proc_Counters : PROCESS(IN_RESETn, M24MHz)
      BEGIN
        IF IN_RESETn='0' THEN
          usg_Counter_7_0 <= (OTHERS => '0');
          IF en_uM8MHz ='1' THEN
            IF usg_Counter_7_0 = usg_MAXCOUNT THEN
              --Reset the counter...
            ELSE
              --... or increment the counter
              usg_Counter_7_0 <= usg_Counter_7_0 + 1;
            END IF;
          END IF;
        END IF;
      END PROCESS proc_Counters;
    Yes in my sim, I see the counter increasing in bursts.
    Sorry, yes the en_uM8MHz signal is high for 3 M24MHz clocks. Hence the source of the bursts.
