14 years ago
Bad code, but no error, will settle for warning :)
This code compiles(!).
always @ (posedge clock ) begin
state <= NextState;
state <= state;
state <= 0;
end
Using the SignalTap it appears that state gets set to 0. Apparently its valid code. Is there a way to at least get a warning out of this?
Thank you,
Steve
    Why would you want a warning for perfectly valid code?
    The user has to take some responsibility!
    You may want to invest in a linting tool.
    I actually use that method when I want a default value on a signal. That way 'a' will always have a value even if I don't assign it in the if statement.
    always@(posedge clk)
    begin
    a <= 1'b0;
    if(something)
    begin
    a <= 1'b1;
    end
    else if(something else)
    begin
    <something that doesn't touch a>
    end
    end
    --- Quote Start ---
    end
    --- Quote End ---
    This seems like a good practice. Now I see the value of such a method.
    Thank you,
    Steve
