Maio
3 years agoAttribute in RTL for Timing Constraints
Hello, For AMD, I used the following methodology to create timing constraints for registers: RTL Code: (* some_attribute = "true" *) reg [31:0] config_register; Constraints: [get_cells -hier -fi...
Nurina
3 years agoHi,
Thank you for using Intel Communities.
As far as I know there is no command for this. But you can see the targets that the attributes apply to on the RTL Analyzer in the latest Quartus Pro software: https://www.intel.com/content/www/us/en/docs/programmable/683236/23-2/inspecting-sdc-on-rtl-constraints.html
Nurina
