11 years ago
attribute 'event usage within procedure
I'm having a procedure (non-synthesizable code) and I am trying to use the 'event attribute on a signal declared as input to the procedure:
   procedure priority_req(signal   tb_control : in  t_tb_control) is
   begin
         while (tb_control.command /= priority_grant) loop
            wait for tb_control.cycle_time;
            wait until tb_control.command'event;
         end loop;
   end priority_req;
tb_control is a signal (although mode 'in' within procedure) of type t_command
where t_command is a record.
From the compiler I am getting the error:
Error, attribute event is only defined for signals.
I have tried all language syntaxes from '87 to '2008, all see it as an error.
Does anyone have an ideea how I can fix/rewrite it so it gets compiled?
    thats because the 'event attribute is not a signal, and hence cannot be waited on.
    instead, use:
    wait on tb_control.command;
    @Tricky
    thank you, the compiler is happy with "wait on".
    Is "wait on signal" accomplished on assignment of signal or value change?
    Wait on waits until an event occurs on the signals in the list, so you can list multiple signals.
    If you want to wait until the the assignment of a signal, you can use:
    wait on my_signal'transaction;
    So in this case it is every time a signal is assigned, even if it is from the same state, eg:
    my_signal <= '1';
    wait for 10 ns;
    my_signal <= '1';
    creates 2 'transactions.
    I am using HDL Designer flow and the error I initially mentioned occurs in the "Generation step" of the ModelSim TCL flow.
    With the proposed 'transaction attribute the tool passes the generation step but triggeres a compile error in ModelSim:
    wait on tb_control.command'transaction;
    tb_control is a record containing a signal "command"
    ModelSim error:
    Attribute "transaction" may not be read from formal signal parameter "tb_control".
    VHDL Compiler exiting
    It seems that various tools interpret these attributes differently:
    1. ModelSim accepts 'event, HDL Designer doesn't
    2. HDL Designer accepts 'transaction, ModelSim doesn't
